6.0 problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-08-2013, 06:51 PM Thread Starter
6.0 problems
I have a 05 6.0 with a 134k on it at 100 k it got a new motor due to a bent rod but now I have other problems . The speedo quit working and the truck is weak even with my sct on performance . With out the programmer the truck will barely do 35 mph. And now the wrench light comes on sometimes when starting and i can kill it and refire and it will go off . Im at a lose cuss the gauges will sweep but will not work could it be in like a limp mode . The motor has studs and egr delete I have already sunk a ton into it I really need I back up and running proper. All help is greatly appreciated.
LA stroker is offline
post #2 of 4 Old 04-08-2013, 07:00 PM Thread Starter
Angry
All so when u first crank it it will flat out run like a bat out of hell for about 400 yards them bam like a brick wall the rpms will drop to like cruising speeds and will not go wot anymore just real slugish .
post #3 of 4 Old 04-08-2013, 07:18 PM
JGI
JGI's Avatar
It could be a bad speed sensor (P0500). Did you have someone pull the codes?
JGI is offline
post #4 of 4 Old 04-08-2013, 07:22 PM Thread Starter
No I have a buddy that built the motor at the dealer ship I have to take it Thursday evening and he's Gona pull the codes free of charge but would that cause a like a limp mode cause at first it's realy fast then it just falls on its face. I tried to pull the dtcs with my sct but it says none were found.
