Help please!!! 2006 ford f-250 6.0 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-08-2013, 11:36 AM Thread Starter
I wanna start by say hi to every one!!! I have one pain in the *** problem with a 2006 f-250 6.0. I have tried almost everything, the motor has been rebuilt and pulled out twice and checked for leaks and every seems fine. Injectors, pumps everything. And the same problem is still there. The truck starts fine cold stays on but after 15 20 min you shut the key off and try to start it again it won't start, cranks fine and picks up pressure but won't start. I think it's something electrical or my computer but I was wondering if anybody on this forum has run into the same problem. Any help would be appreciated. The truck is going on 8 months at the shop already
Goatjuice6.0 is offline
post #2 of 2 Old 04-08-2013, 12:09 PM
RedneckYankee's Avatar
Do you have anyway to monitor your truck? I had similar problem truck was running fine and shut it down with no restart. Had good fuel pressure, oil pressure but no start. Found I wasn't getting sync to PCM. After beating my head against the wall and shaking wiring harnesses she started. Everything was good oil and fuel pressures FICM and battery voltages good. Shut her down to and tried to restart no start. Shook harness on driver side and she re-fired. While running re-shook wiring harness on driver side and pulled a code for Cam Positioning sensor low. Traced wiring and found where the shielded cable was spliced together to the sensor plug was shorted together. Took a new piece of shielded cable and replaced cable. Soldered and heat shrinked ends problem is now gone. The connections were previously just taped with no heat shrink. Don't know if that's your problem but worth checking on due to vibration that wiring harness gets pretty beat up. Good luck
David
"Hold my beer and watch this"
2005 Excurstion Limited RWD
Sinister EGR Deleate
SCT Tuner MPT Custom Tune Econ/Perf
Dash Boss Monitor
Blue Spring Upgrade
Nitto Terra Grappler 285/75/16
Bilstien 4600 shocks
No Kitty
4" Straight piped
Studded
Updated Stand pipes and Dummy Plugs
1996 F250 XCLB 4x4
4" Ruff Country Lift
Ruff Country N2O Shocks
RedneckYankee is offline
