P0500 code - Ford Powerstroke Diesel Forum
post #1 of 24 Old 04-07-2013, 03:26 PM Thread Starter
P0500 code
Guys, today I was trying to check fuses because my 4wd will not engage. Everything looked ok and I had to meet the wife for dinner so I put covers back on and took off. All of a sudden I have abs light on and no speedo. No clue where to start on this one. My truck is 06 f250 Tuscany with 93k miles. All of a sudden things are falling apart. Help.
usctrack is offline
post #2 of 24 Old 04-07-2013, 03:48 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
rear differential speed sensor
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 24 Old 04-07-2013, 04:00 PM Thread Starter
Where is it and how do I check it? Thanks
usctrack is offline
post #4 of 24 Old 04-07-2013, 04:27 PM
PHYRMN's Avatar
Its on the rear differential, Check the resistance. Should be 800-1800 ohms
P0500 - Vehicle Speed Sensor A Description: Indicates the powertrain control module (PCM) detected an error in the vehicle speed
information.
Possible Causes: • Open in the VSS harness circuit
• Short to GND in the VSS harness circuit
• Short to PWR in the VSS harness circuit
• Damaged wheel speed sensors
• Damaged wheel speed sensor harness circuits
• Damaged ABS module
• Damaged PCM
Diagnostic Aids: Monitor the VSS PID while driving the vehicle. This DTC is set when the PCM detects a
sudden loss of vehicle speed signal over a period of time. If vehicle speed data is lost, check
the source of the vehicle speed input.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 24 Old 04-07-2013, 04:39 PM Thread Starter
Will do. Just weird that it happens as soon as I check fuses for the 4wd. 4wd stops working, #4 injector is going out, and now this. Get this thing paid off and then it starts falling apart.
usctrack is offline
post #6 of 24 Old 04-07-2013, 04:44 PM
PHYRMN's Avatar
I know the feeling, but I have to remind myself that nothing lasts forever. I love my truck, it was the worst 3 weeks waiting to get my studs and oem gaskets done.
PHYRMN is offline
post #7 of 24 Old 04-07-2013, 05:30 PM Thread Starter
I just need to take some time and start tracking down these issues.
I saw someone mention to remove both negatives from the batts and reset the system but I have a custom tune so I would be worried about that.
usctrack is offline
post #8 of 24 Old 04-07-2013, 05:40 PM
PHYRMN's Avatar
Removing the battery cables will have no effect on custom tuning.
PHYRMN is offline
post #9 of 24 Old 04-30-2013, 08:02 AM Thread Starter
Removed battery cables this weekend. No change! Finally found my voltmeter to check the ohm and viola - nothing! Looks like the sensor went bad.
Now to replace - Does anyone have the item number for that sensor? I have seen sensors from $20 to $120 but none say they are the right number?
Per an online search i found F85Z-2L373-AB. Is that correct? are there any others to cross reference?
Thanks all
usctrack is offline
post #10 of 24 Old 04-30-2013, 03:36 PM
PHYRMN's Avatar
This should be the correct part number. (DY-998 Vehicle Build Date before: 12/4/2005),
(DY-1073 Vehicle Build Date after: 12/5/2005). I'm thinking that the DY-1073 replaced the DY-998.
PHYRMN is offline
