05 6.0l Starts and dies - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-07-2013, 02:45 PM Thread Starter
Hi guys, I have a 2005 f250, i pulled out of the driveway this morning and it died. It did restart once or twice, idles for a few seconds and dies.
I only have a codes reader, U0105,U1900,U0306,P1000,P2617. Some or all will reset just from cranking.
I have 49 volts at ficm, key on and cranking. Fuse 22 is good,and ficm relay is good. Oil pressure gauge moves to 1/2 when cranking.
I can bring home a snap on modis tomorrow, just wanted some preliminary advise, have to go get a chain and drag it back home.
Dave
Djdnl is offline
post #2 of 11 Old 04-07-2013, 03:24 PM
PHYRMN's Avatar
Lets find out what the ICP and IPR readings are when its cold with just the key on, while trying to starting cold, when warmed up, and trying to start when its warmed up.
Here's some reading;
No start issue? Look here.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 11 Old 04-07-2013, 04:09 PM
southend's Avatar
You can pull the upper fuel filter and see if it is empty. How much fuel is in your tank?
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 11 Old 04-07-2013, 05:25 PM Thread Starter
Thanks for replies. Yes tank is 3/4 full and fuel in upper filter.
PHYRMN I will post readings tomorrow as soon as I can. I dont think it will run long enough to warm up if it evens starts. Thx. dave
Djdnl is offline
post #5 of 11 Old 04-07-2013, 05:41 PM
PHYRMN's Avatar
Lets at least get, the IPR and ICP readings while its trying to start, if its a failing ICP sensor you can unplug the ICP and the ECM will default its readings and allow it to start without the ICP sensor inputs. IPR will tell us what duty cycle its trying to achieve to create enough High Pressure oil to start the vehicle. Once we eliminate the High Pressure Oil system we can move on to other things.
PHYRMN is offline
post #6 of 11 Old 04-07-2013, 05:53 PM Thread Starter
ICP sensor is on the front of the right head? Unplugged it and it still wont run.
I have been reading this site...lol. Thx again.
Djdnl is offline
post #7 of 11 Old 04-07-2013, 06:42 PM
PHYRMN's Avatar
I would still be interested in the IPR, ICP readings.
PHYRMN is offline
post #8 of 11 Old 04-08-2013, 04:41 PM Thread Starter
IPR. 50% cranking
ICP 1.2volts cranking, up to 2 volts
ICP pressure 1691psi cranking, 920 when it ran for 3 seconds
ICPDSD pressure 1600 cranking, 900 when it ran
Still sets codes U0105 and U0306 every time, even with KOEO self test.
Can read 48 volts at ficm with scanner(snap on modis)
logic power, main power and vehicle power reads 11.2 with scan tool.
I think the Ficm is ng?
Dave
Djdnl is offline
post #9 of 11 Old 04-11-2013, 05:49 AM Thread Starter
Any help please?
Djdnl is offline
post #10 of 11 Old 04-11-2013, 05:59 AM
Looks like your batteries or alternator is going out. The FICM FLP and FMP (or whatever they are called) should be 12V. Vehicle power should be over 12.5.
Had the batteries load tested? Is alternator putting out juice? Should see 13.5 volts from the alternator...
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
