No power at low RPM - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-07-2013, 10:26 AM Thread Starter
No power at low RPM
Hi, I'm looking for some help. I have a 07 6.0 which isn't making any power down low. I thought it was a turbo issue so I replaced it and still the same. I'd a pressure test and no air leaks. I also cleaned my EBP sensor. That didn't change anything. I have a motos snap on scanner. So I can run tests I just need to know where else I should start looking.
Hotcarl is offline
post #2 of 8 Old 04-07-2013, 10:35 AM
How much psi is it making at high rpms or will it even do that?
gage is offline
post #3 of 8 Old 04-07-2013, 10:48 AM Thread Starter
About 25 26psi. The top end feels good!
Hotcarl is offline
post #4 of 8 Old 04-07-2013, 10:55 AM
Does it idle rough?
gage is offline
post #5 of 8 Old 04-07-2013, 10:57 AM Thread Starter
No idles fine. I did a injector contribution test and they seem to be all working the same
Hotcarl is offline
post #6 of 8 Old 04-07-2013, 11:03 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Could be VGT solenoid.
What is EBP, BARO, and MAP all doing with KOEO? Should be almost identical.
Maybe fuel pressure issue too.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 8 Old 04-07-2013, 11:07 AM Thread Starter
The Vgt solenoid is new. I just put a new turbo on it yesterday. EBP was reading 97 KPA at hot idle.
Hotcarl is offline
post #8 of 8 Old 04-07-2013, 06:46 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Let me put it this way:
Test VGT duty cycle driving. And EBP, MAP, and BARO at KOEO.
Guess it could be FICM too.
4R100, 2wd
330,000 + miles
jesilvas is offline
