Squeak at Startup - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-07-2013, 05:41 AM Thread Starter
nolefanreed15's Avatar
Squeak at Startup
Lately when starting "cold," (l live in Florida, temps get down to about 60 at night) I have been hearing a slight chirp for the first few minutes when running. Occurs with A/C on or off, no increase chirp with rpm (that I could hear), and about 3 months ago I replaced a frozen tensioner and an alternator with bad bearings that was causing the same kind of sound. Is it definitely the idler pulley?
-2005 F250 6.0, EGR Delete, Oil Cooler Upgrade, ARP Headstuds, 5" MBRP Exhaust, Blue Spring Upgrade, SCT X3 w/ IDP Tunes, 17" MetalMoto's, 35" Toyo Mt's, Retro Solutions 55 watt HID Headlights, Xenon Fogs, 08 Tail Lights
nolefanreed15 is offline
post #2 of 7 Old 04-07-2013, 06:04 AM
southend's Avatar
It is likely, you can take the idler pully off, pop the bearing out, take it to the parts store and get a replacement for about $8 or so. It was the belt on my 96 obs causing the chirp.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 7 Old 04-07-2013, 06:10 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Don't forget the belt...
I thought my tensioner was making noise so I replaced it only to discover it the noise wasn't coming from any pulleys or the tensioner...
It was coming from the belt.
I just replaced it yesterday and the squeak is gone.
I'd recommend doing it with a buddy though, so one person can route the belt up top and the other person can be under the truck to route them onto the lower wheels.
Good Luck!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #4 of 7 Old 04-07-2013, 06:28 AM Thread Starter
Thanks for the quick replies! However I don't think it is the belt because after replacing my tensioner the noise stopped for about 3 months. It just recently started this week.
post #5 of 7 Old 04-07-2013, 06:33 AM
dfuzz78's Avatar
Then it is most certainly the belt.
The new tensioner was able to tighten the belt back up for 3 months, but the belt was still wearing out.
It has now tighten as much as it can with the worn belt.
My belt looked new with no crack or signs of wear, but it was streched out.
It's a $52 belt at Napa...
Denis "Lt. Sled"
dfuzz78 is offline
post #6 of 7 Old 04-07-2013, 04:58 PM
jaysshortbus's Avatar
Get a spray bottle with water in it spray belt 1 time while running if squeak stops its your belt !! Atleast thats what I was told and tried and I ordered a new belt today !!
Jay
jaysshortbus is offline
post #7 of 7 Old 04-07-2013, 05:48 PM
PHYRMN's Avatar
x2 on the belt.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
