Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum
Old 02-04-2008, 10:06 AM
Arkmx Arkmx is offline
Question Fuse #45 Blows (Ignition switch run/start feed)
I know a short caused a blown fuse, but has anyone experienced the #45 fuse going out? When it does you loose all the gages in the Instrument panel, (Speed, Tach, Fuel, Oil, Odometer etc.) Sometimes 3 or 4 times a day some days nothing!! Tried a 15 amp and it still goes out.... It does not seem to matter if you are running down the road at speed or just getting up to speed. I can't get it to do it when I am wiggling wires or shaking the truck myself.
Any ideas where to look?? Errrr....
2003 F250 SD 6.0L with 164K miles.
Thanks in advance!!
Jim.
Old 02-04-2008, 10:18 AM
korterman1 korterman1 is offline
A short is very difficult to locate @ times, Once i had a short and the only way I found it was @ night when I could see a spark, (mine ended up being a dime the cigarette lighter) One other ? have you recently done anything to your wiring? a mod. of any kind.
Old 02-04-2008, 10:27 AM
No wiring mods.... I did have the truck worked on recently where they pulled the cab off.... Wondering if a wire could have been pinched etc.?
But the fuse did blow once prior to the work being done.....
does anyone know what exactly runs through the #45 Fuse circuit??? Also waiting to here from the Dealer on that same question.
JG.
Old 02-05-2008, 10:15 AM
Fixed problem...
To make a long story short, the problem was with the Tow/Haul switch wiring. It had rubbed through and was grounding where the shift lever connects under the steering column cover.
Throughly taped the area and all is well now!
So if you have his problem look there first...
Later...
JG.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
