EGR Cooler, Oil Cooler, HPOP SCT Fitting NO START - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-06-2013, 09:14 AM Thread Starter
Rob05F350's Avatar
Angry EGR Cooler, Oil Cooler, HPOP SCT Fitting NO START
I replaced the EGR Cooler, Oil Cooler, and STC Fitting on the HPOP.. After getting everything put back together truck will not start, all it does is crank.. I know it will be a bit before it will start due to the oil rails being drained... Any estimates on how long it has to crank??? While cranking the motor spins fairly easy and dosent seem like it has any compression... HELP
Rob05F350 is offline
post #2 of 5 Old 04-06-2013, 10:48 AM
Aretoo's Avatar
Do you have a set of gauges where you can watch the ICP pressures. It will need to be at 500psi before it will start. This info will help figure out where your problem may be. I know a couple of guys said they drained their batteries it took so long to start after taking off the HPOP.
Hello, my name is Nathan...and I am addicted to my skinny pedal!
2006 F250 Crew Cab Short Bed
Harley Davidson Edition # 01592
MODS
ARP Studs
Edge Insight CTS with EGT
IPR Gen2 EGR Delete
Sinister Coolant Filter
MBRP 4" turbo back
PHP Atlas 40 FICM Tune
Gearhead tunes
Rotella Ultra ELC
Aretoo is offline
post #3 of 5 Old 04-06-2013, 10:54 AM Thread Starter
Rob05F350's Avatar
I dont have any gauges to check the poressures. I am trying to locate a scan tool to check them
post #4 of 5 Old 04-06-2013, 11:38 AM Thread Starter
Rob05F350's Avatar
Just tried cranking it again and it is trying to start.. but my batteries keep draining down before it starts... I will let them charge more and try again
post #5 of 5 Old 04-06-2013, 07:03 PM Thread Starter
Rob05F350's Avatar
It finally came to life.. It is alive and running
