FICM/Oil Cooler Failure? Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-06-2013, 03:47 AM Thread Starter
I just received my Dashboss yesterday and got it hooked up, My Ficm voltage at idle is between 47-48v but when I am running down the road it drops to 36-38v, from what I have read, I think I need to have it repaired?
I also show my ECT at 180 and even in 47 degree weather at 70mph after 20 miles it does not raise at all, my EOT is running at 220, I know my delta's are off but is it a bad thermostat or oil cooler going bad? Any imput would be appreciated. Its a 2004 f-250 CCSB SRW with EGR delete and blue spring mod.
bfordu is offline
post #2 of 8 Old 04-06-2013, 04:32 AM
PHYRMN's Avatar
Your correct on all 3 issues, get the FICM repaired, a new thermostat, and the oil cooler is showing its inefficiency.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 8 Old 04-06-2013, 05:16 AM Thread Starter
Where can I get a good replacement FICM From, and what oil cooler should I go with, might as well do the oil pump why I am there, anything else?
bfordu is offline
post #4 of 8 Old 04-06-2013, 07:45 AM
06Lariat_'s Avatar
I think there's a good place called ficm repair .com?
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #5 of 8 Old 04-06-2013, 04:10 PM
PHYRMN's Avatar
Ford oem cooler kit, 3C3Z6A642CA.
PHYRMN is offline
post #6 of 8 Old 04-08-2013, 09:14 AM Thread Starter
Well ordered a exchange ficm from ed at ficm.com on Saturday so hope to see that soon, ordered a new cooler, turbo bolt/gasket kit, and exhaust manifold gaskets. Anyone have suggestions on what else I will need.
bfordu is offline
post #7 of 8 Old 04-09-2013, 02:50 PM
southend's Avatar
A coolant filter is a must.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #8 of 8 Old 04-09-2013, 03:27 PM
PHYRMN's Avatar
Absolutely southend, good catch!
PHYRMN is offline
