rough idle no power - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-04-2013, 11:20 AM Thread Starter
rough idle no power
truck died while while my guys were working yesterday had it towed back to my shop. i pulled 15 codes out of the computer.
p0261 inj cir. low #1 cylinder
p0264 " #2 "
p0267 " #3 "
p0270 " #4 "
p0273 " #5 "
p0276 " #6 "
p0279 " #7 "
p0282 " #8 "
p0275 cyl 5 contribution or balance malfunction
p0278 "cly 6 "
p0341 cam position sensior circuit a range/performance
p0404 ex gas recir. rang performance malfuntion
p0405 ex gas recir. sensior a circuit low
p2614 cam position output circuit open
p0683 glow plug control module to pcm comm circuit
truck would not start checked the hi press. oil got 1300 psi. checked all fluids at normal level. checked ficm voltage 48v. buzz testes all injectiors they test fine. so i cleared the the dtc and the truck starts up and runs. but has a rough idle and no power. Any ideas on what it could be or what to check next any input would be appreciated.
JAlandscape is offline
post #2 of 3 Old 04-04-2013, 11:32 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
sounds/looks like it needs a cam sensor, I'd try that to start with...
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 3 Old 04-04-2013, 11:38 AM Thread Starter
thanks ill give that a try. but i just realized i left out thats its a 04 f450 6.0l.
