2004 6.0 injector 3 circuit low p0267 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-03-2013, 07:52 PM Thread Starter
chardnay10's Avatar
I have an 04 with dtc code p0267 injector 3 circuit low, it wont seem to go over 65 and has not very much power it sounds like ticking at idle, there are no other codes except the 1. What could cause this issue ficm harness problem?
chardnay10 is offline
post #2 of 8 Old 04-03-2013, 08:06 PM
Davyb_23's Avatar
You definitely got an injector out. That happened to me awhile ago they fixed it and if ran fine after they replaced the injector...
Davyb_23 is offline
post #3 of 8 Old 04-03-2013, 08:30 PM Thread Starter
chardnay10's Avatar
hmmm thats what i was wondering but everyone says its a connection to the injector it self or ficm harness connection
post #4 of 8 Old 04-04-2013, 06:13 AM
PHYRMN's Avatar
Get a multimeter, check the resistance (ohms) between pins 1 and 2, and 3 and 4 on the injector pig tail. The readings should be around .8 ohms. A reading in this area will rule out bad injector coils.
Here's a pinout that should help.
https://www.dropbox.com/s/lrite66dmy...tor_Pinout.pdf
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #5 of 8 Old 04-07-2013, 05:16 AM
southend's Avatar
This is a good place to start. Although your truck should easily get over 65 mph even with a bad injector. You have something else going on. The value given is at ambient temp. Do you have a monitor? You may want to pull your egr and check it also.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #6 of 8 Old 04-07-2013, 07:50 PM Thread Starter
chardnay10's Avatar
Somethin else goin on as in what? would the egr cause this code is what your saying?
post #7 of 8 Old 04-07-2013, 11:24 PM
southend's Avatar
Maybe you are not building boost, your fuel pressure is low, idk, but it could be something in addition to a failed injector.
southend is offline
post #8 of 8 Old 04-08-2013, 05:29 AM
I agree you might have something else going on aswell. with one bad injector your truck will be able to get over 65 i had one go out on my truck and the only way i noticed was a little vibration at 55+ but i could get up above 65 no problem. I thought it was a problem with my trans at first because it would only vibrate when it kicked into over drive. Lots of other things to check, cant pin point any just wanted to share my experiance with one bad injector.
03xl350 is offline
Tags
ficm , injector harness , p0267
