6.0 issues with TPS - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-03-2013, 07:10 PM Thread Starter
6.0 issues with TPS
I have a 03 f350 with the 6.0, I have replaced my TPS multiple times since 12/2012 I also replaced the FICM and my truck keeps throwing a check engine light for the TPS also since I replaced the FICM when I am driving and holding the same speed the RPM's go up and drop like I was letting off the pedal and pushing it again. what could it be now??? any suggestions??
samnextdoor1 is offline
post #2 of 10 Old 04-03-2013, 07:12 PM
mackattack6.0's Avatar
Do the rpm drop around 45-50?
'03 6.blow F250 CCSB lariat, ARP Studs, Ford Gaskets, New Oil Cooler 75k, XDP EGR Delete, SCT Livewire TS with Looney Wild from Vivian, MBRP 4" straight pipe, Blue Spring Update, Zoodad Mod, High Idle, Fog Light Mod, 73,XXX
mackattack6.0 is offline
post #3 of 10 Old 04-03-2013, 07:18 PM Thread Starter
Yes it only drop by a little bit I'll drop from 2000 to just under and back up again then it throws the check engine light after a little while
post #4 of 10 Old 04-03-2013, 07:20 PM
Hmm. Mine will be around 1800 and drop to 1300. I have been told its just the TC locking up. But check engine light i haven't had
post #5 of 10 Old 04-03-2013, 07:21 PM Thread Starter
Mmm I'm thinking it's an electrical problem. ...
post #6 of 10 Old 04-04-2013, 06:03 AM
PHYRMN's Avatar
Somebody correct me if I'm wrong, but I thought the TPS was taken out of the strategy back around 05. I have an 03 and have completely removed my throttle body, put on an 05 and later intake elbow and it never through a code.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #7 of 10 Old 04-04-2013, 07:09 AM Thread Starter
How much do that run you to do?
post #8 of 10 Old 04-04-2013, 10:35 AM
PHYRMN's Avatar
Pretty sure I got one off of Ebay for around 150.00
PHYRMN is offline
post #9 of 10 Old 04-05-2013, 04:00 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
what is the exact code? 03s have a dummy throttle body with no throttle plate in it. The plugs are there but they don't connect to anything. The EGR emissions requirement wasn't mandatory until 04. Before then no throttle plate was necessary because there was no specified amount of EGR flow.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 10 Old 04-05-2013, 04:20 PM Thread Starter
I will check as soon as I can
Tags
tps , tps sensor
