2003 6.0 4X4 not working, HELP - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-03-2013, 06:45 PM Thread Starter
Hi, im knew to the forum and ive never really had a problem with my truck till last week when i went to move my truck out of some gravel and it sank alittle and got stuck, when i went to engage my 4x4 i got the 4x4 light on the dash but it didnt accually catch, and i had already locked the hubs, my display also wont show it going into 4 low, does anyone know what this could be? any help would be much appreciated, and its electronic 4x4 switch, not manual on the floor, thankyou
Alex north is offline
post #2 of 6 Old 04-03-2013, 06:52 PM
PHYRMN's Avatar
Sounds like the actuator on the transfer case isnt engaging, or is stuck. When was the last time you used 4x4 and it worked?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 6 Old 04-03-2013, 07:23 PM Thread Starter
At least since last summer, never had to engage it this winter
post #4 of 6 Old 04-03-2013, 07:46 PM
Blue Goose's Avatar
Check the two relays between the battery and fender on the drivers side, it's a common problem that's easy to fix. Hope this helps.
06 KR 250
Blue Goose is offline
post #5 of 6 Old 04-04-2013, 04:06 AM Thread Starter
Ok thankyou, I'll check that tonight
post #6 of 6 Old 04-04-2013, 06:57 AM
PHYRMN's Avatar
Most 4x4'rs and Ford recommend cycling the 4x4 system at least once a month.
PHYRMN is offline
