Oily motor - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-03-2013, 05:08 PM Thread Starter
Oily motor
Just installed a leveling kit today and I saw that the motor (right above the exhaust manifold) is wet; with what I do not know. It appears to be oil but the level hasn't changed in weeks. Maybe something to do with injectors or part of the fuel system? Leaky o rings somewhere?
2002 F-250 Bone Stock
Ronin114 is offline
post #2 of 5 Old 04-03-2013, 06:48 PM
PHYRMN's Avatar
What does the fluid smell like, diesel, oil or coolant?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 5 Old 04-04-2013, 12:20 PM Thread Starter
It's pretty odorless to be honest... just a really black, oily substance. The motor is wet around th exhaust manifold but nothing is leaking onto the ground. Like previously stated, no oil or coolant loss and I haven't noticed any "disappearing" fuel.
Ronin114 is offline
post #4 of 5 Old 04-04-2013, 12:59 PM
Mines the same on the passenger side, but ive found that the prev. Owner had worj done and the valve covers were bent at the bolt holes because the bolts have a centering grommet on it that if you tighten down it will bend a point into it. Plus the gasket was messed up with the sharp edges digging in. I had mine off and flattened the cover surface using a vise and a socket to make them smooth ( a week ago). Ive found its best (depending on condition of gasket, if you set the gasket on the cover and pop your bolts through it will hold it in good enough to carefully put on the head. Or just do a 1 turn in so its loose on all bolts then pull up on cover as you hand tighten the bolts. Also the bottom back bolts on pass side are impossible to torque so its really just guessing with a wrench.
Check the bolts on the valve covers, if theyre grimey then its valve cover gaskets most likely
ajfrac is offline
post #5 of 5 Old 04-04-2013, 05:26 PM
Quoted: 3 Post(s)
Could be glow plug harness as well, hard to say
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
Tags
fuel , injector , leak , o ring , oil
