P0678... replaced parts, cant figure it out - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-01-2013, 03:53 PM Thread Starter
1fastsvt0816's Avatar
Quoted: 9 Post(s)
I did my HG's about 2 months ago or so and went ahead and replaced all the glow plugs and the glow plug harnesses (from Tousley) and started getting a P0678. I was doing some reading on the internet and unplugged the GPCM and tested the glow plugs and all were at 1 ohm. Over the weekend i replaced the GPCM (oem from Tousley) this weekend, cleared the code and it went away for a day and a half and it came back on this afternoon with the same code (P0678) Do you guys have any suggestions?? The only other thing i can think of from reading is to replace that one glow plug again and/or check the battery terminal connections.
1fastsvt0816 is offline
post #2 of 3 Old 04-01-2013, 06:14 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Possible wiring or connection issue.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 04-02-2013, 04:58 PM Thread Starter
Quoted: 9 Post(s)
well, i just went under the truck to see if i can push down on the glow plug harness for cylinder 8 and it was pretty much just resting on top of the hole for the glow plug. I can swear that when i had the heads off the truck when i was doing the HG's i made sure they were all seated on. Ill see how it does now.
