Sputtering - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-01-2013, 09:58 AM Thread Starter
Sputtering
I have been having a problem with my 2007 f250 in the morning when I pull out of the driveway it sputters some. Normally it has went away after a minute or 2 and I doesn't happen the rest of the day. I have been letting it warm up in the morning it seemed to help. This morning it did it after letting it warm up then after driving 10 minutes on the interstate at 70 mph it did it again sputtering and shaking. When I let off the gas it stopped and came and went till I got to work. Did again when it to lunch but immediately went away. Any ideas what the problem is? Thanks.
CarolinaCustom is offline
post #2 of 9 Old 04-01-2013, 03:01 PM
midnite rider's Avatar
Quoted: 285 Post(s)
could be a number of things. do u have any way of monitoring your engine like a edge insight
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #3 of 9 Old 04-01-2013, 05:29 PM Thread Starter
No I don't have a tunner or monitoring system. Truck is stock except for exhaust. I'm going to take it to a dealer this week and have them change my fuel filters and air cleaner and have them hook it up and see what the problem is. It ran fine on the way home. I was thinking maybe injector or hpop. Truck has 92k miles.
post #4 of 9 Old 04-01-2013, 06:20 PM
twoicebergs's Avatar
Quoted: 42 Post(s)
You need a monitor, but it sounds like stiction. Get a buzz/contribution/balance test done. If they recommend replacing the injector, maybe you can try the fix in my sig.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 9 Old 04-02-2013, 05:06 AM Thread Starter
It did it again this morning for about 300 yards down the road. I turned around and came back. While it was doing it black smoke was coming out the exhaust
post #6 of 9 Old 04-02-2013, 02:33 PM
ps_lane01's Avatar
Quoted: 2 Post(s)
Try rev-x oil additive. It Should atleast help
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #7 of 9 Old 04-03-2013, 07:03 AM Thread Starter
I tried to crank it this morning and it would crank right up then cut right back off with a puff of black smoke. I have a guy coming over this afternoon to try and get the codes off it and see what the problem is.
post #8 of 9 Old 04-03-2013, 04:31 PM Thread Starter
Guy from a dealership came and hooked it to his computer and said the ficm was bad. He recommended getting a new oem ford one. I looked up ficmrepair.com and I can get mine rebuilt with lifetime warranty for a little more than half the cost of a new one. And recommendations on what I should do.
post #9 of 9 Old 04-03-2013, 06:39 PM
Try some Archoil. I have some extra for sale!
Callor text me
205-617-2145
205mx is offline
