Uggg still hydrolocking - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-30-2013, 08:09 PM Thread Starter
So my truck shut off and hydrolocked on the way home from 50 miles from home after a 1000 mile 24 hour trip to get my doughter so I pulled egr valve and it was loaded with a sticky black paist so I changed oil cooler and did an egr delete. Cranked it fore awile tell I got oil pressure and it hydrolocked with fule withen seconds after I got oil pressure I put a code reader on it and it gave me two codes on the gpcm and a code saying that the batteries we're recently disconnected wich they were to change the cooler. So dose anyone have any ideas on how to fix it
shannon1977 is offline
post #2 of 4 Old 03-30-2013, 08:33 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Pull the glow plugs and see which cylinder shoots fluid out of it. Could be coolant or fuel.
dhanna6powerstroke is offline
post #3 of 4 Old 03-30-2013, 09:07 PM Thread Starter
#2 cylinder full of fule
post #4 of 4 Old 03-31-2013, 12:26 AM
Mod Newbie
Quoted: 20 Post(s)
Sounds to me like cylinder 2 injector hung open on you. Crank the engine over with the glow plug out, remove #2 injector. Before reinstalling the new injector, crank the engine over with the old injector and.glow plug removed to eliminate and excess fluid. Reinstall new injector and your oil rail. Crank engine over again for safe measure. Install the glow plug and button everything up. Start truck and monitor.
