Hiccup? Need some input - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-30-2013, 04:38 PM Thread Starter
I'm on a trip towing my 5th wheel x-country, moving actually. Started noticing a little hiccup, under load, if I let the rpms drop while going up an incline. If I putthe throttle down it goes right away. Only one or two little hiccups and too fast to catch on my monitor. Truck did not do it w/o the trailer. Otherwise thing is running fantastic. I read an old thread where someone had the same problem and is possibly vgt actuator and oil line. Need some thoughts here. Thanks in advance...
2006
F350
Crew Cab
Long Bed
Auto trans
4x4
Dually
"a true hotrodder wouldn't be content until he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less just makes him want to go faster."
Fireaxe is offline
post #2 of 3 Old 03-30-2013, 05:45 PM
southend's Avatar
Maybe your egr valve is sticking?
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 3 Old 03-30-2013, 06:24 PM Thread Starter
Just cleaned EGR valve. No codes being thrown. Thought it was the trans or the trailer bucking but it's not that. Kinda difficult to figure out cause its hard to reproduce. Also installed BPD EGR cooler and cleaned the intake.
2006
F350
Crew Cab
Long Bed
Auto trans
4x4
Dually
Fireaxe is offline
