04 6.0 F250 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-30-2013, 12:25 PM Thread Starter
04 6.0 F250
I have a 04 F250 6.0 with over 200k miles. I have not had much trouble with it at all but last week I began having white smone coming from exhaust and from under driver side of hood. It idles a little rough but still has power when eccelerating. I thought it may be bad fuel as it seemed to start after putting fuel in it. When eccelerating the smoke turns black and is more than normal. I have not tried anything yet as I have not had time this week. The antifreeze level has not changed and it does not seem to be getting any hotter than normal.
I had the HPOP and ICP changes last year.
Any help would be great....
sparkyemtp is offline
post #2 of 2 Old 03-30-2013, 04:06 PM
southend's Avatar
You really need a monitor, or we will just be guessing....read up on the sticky for monitoring. It sounds like you are overfueling, which can cause major problems if not taken care of. You need to be able to pull stored codes. Check your oil level to see if it is high on the stick.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
