Erratic Temperature Reading (2006 E-450) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-30-2013, 12:02 PM Thread Starter
New guy could use some help on this. Haven't taken it to a shop yet and would rather not if I can avoid it.
Yesterday I was driving it and the temperature got just above mid-range on the temp gauge. The "check gauges" light came on and then within 30 seconds it had cooled back down and the light went off.
Today my crew was driving it. They said the temperature was going up and down erratically but never past the operating range on the gauge. The "check gauges" light never came on.
Is this normal for an E-450? We've only have the truck for a month so I'm not very familiar with the truck yet. I just changed the oil and filter with Rotella 15w 40 earlier this week. Doesn't appear to be leaking any coolant.
Any help would be greatly appreciated.
mediocrehauler is offline
post #2 of 5 Old 03-30-2013, 04:08 PM
southend's Avatar
You need a monitor, read up on the monitoring stickies. That guage on the dash is useless. Without a monitor, we're just guessing. A monitor can also pull stored codes.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 5 Old 03-30-2013, 04:50 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
you definitely need a monitor. A code like fan clutch signal missing wouldn't set a check engine light and could definitely be the cause.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 5 Old 03-30-2013, 08:57 PM Thread Starter
Thanks for the replies guys. I'll try to get a monitor asap. I guess I'll have to let a shop look at it in the mean time.
post #5 of 5 Old 03-30-2013, 09:19 PM
Mike OB's Avatar
The gauge only works while it is under water-coolant, if you are low on coolant it can cause what you are seeing, check the coolant level.
Mike OB is offline
