ICP pressure ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-29-2013, 11:02 PM Thread Starter
ICP pressure ?
What should my ICP psi be at a warm engine idle? I had a no hot start problem but did the updated STC fitting, stand pipes and dummy plugs and all 4 passenger side injector o-rings because one was really bad. I didn't do the other side because I already had it back together. Now it starts when hot but it cranks over longer than normal. My ICP when hot reads 580. Should I be OK or should I tear down the drivers side again and do the rest of the o-rings?
Deezldan is offline
post #2 of 6 Old 03-30-2013, 05:23 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
you need to run the engine hard to purge all of the air out of the high pressure oil system. 5 or 6 good hard wot runs should be enough, either that or 15-20 miles of normal driving.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 6 Old 03-30-2013, 08:27 AM
your ICP looks right for a hot engine. What is more telling is IPR. I am thinking the IPR should be at 20% or so when idling. It the IPR is at 60% when idling to hold the ICP up, that means you have a problem.
Go look for a post where someone lists the IPR% and ICP at various temps.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 6 Old 03-30-2013, 09:22 AM Thread Starter
Ok thanks guys I appreciate it
Deezldan is offline
post #5 of 6 Old 03-30-2013, 09:27 AM
PHYRMN's Avatar
IPR typically will be less than 30, mine is 28, and ICP 650 +-50 on a healthy HPO system.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #6 of 6 Old 03-30-2013, 05:01 PM Thread Starter
How do I figure out what my IPR is? I just got the full color and touch screen edge monitor but can't find anything on the IPR on it. How are you guys getting a percentage?
Deezldan is offline
