Cruise control has hard kick using brake or the off button! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-29-2013, 03:26 PM Thread Starter
Onefast96svt's Avatar
No matter what I do to get cruise to cut off it feels like someone just rear ended me. The only way I can disengauge it easily is to speed up the cut it off. Anyone have any ideas what's up or is this normal.
Onefast96svt is offline
post #2 of 6 Old 03-29-2013, 03:28 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Works that way on my 2000 also. It's just cause you're under a load.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 03-29-2013, 03:36 PM
PHYRMN's Avatar
Is it tuned? I have a tune that keeps the torque convertor locked in overdrive. I get a good thump from the drive train when I take it out of cruise by using the brake or the off button.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #4 of 6 Old 03-29-2013, 03:40 PM Thread Starter
Yeah I do, that's what I was thinking but wasn't sure. I'm going to get a custom tune soon so ill see if they can do something with it. Thanks.
post #5 of 6 Old 03-29-2013, 03:43 PM
PHYRMN's Avatar
If you find a tuner that can program the overdrive lock, but allow the torque converter to just unlock when you turn off the cruise or touch the brake please send me a pm.
PHYRMN is offline
post #6 of 6 Old 04-01-2013, 12:20 PM
Int.Tech04's Avatar
mine does it too, 04 CCSB FX4. figured it was normal. im also running 35's and a 4in lift
-Tyler- -Navistar Technician-
2004 F250 CCSB FX4 6.0 - XDP EGR delete, BPD Oil Cooler Relocation, SCT Livewire TS, 315/75/16 Falken Wildpeak A/T's, Rough Country 4in, stock DP with 4in straight pipe.
Int.Tech04 is offline
