2006 f350 problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-29-2013, 03:24 PM Thread Starter
2006 f350 problems
I got a 06 f350, it stars ok dies few times till warm, smokes a little at idle, codes are P0283
P0282
P0284
P2617, it's gutless idles rough, I pulled the ficm and connector to Injector 8 and one pin is slightly black, should I change injector 8 pig tale and ficm harness anyone have similar problems??
Also I have the 4x4 and low range light as well as brake light on, and it constantly beeps until I play with tcase harness sometimes it goes away, it's gott be shorting but I'm curious if there's any common problems
jmccart is offline
post #2 of 6 Old 03-30-2013, 04:15 AM Thread Starter
Anyone have similar problems?
jmccart is offline
post #3 of 6 Old 03-30-2013, 05:34 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
It sounds like you've also got a short somewhere in the #8 injector circuit, it could be the injector itself, the ficm internally or anywhere in between.
Nothing offhand on an f-series. I have heard of injectors shorting out internally and causing strange problems related to no-starts and stalling out.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 6 Old 03-30-2013, 06:07 AM Thread Starter
Ok thanks I see the ficm is tagged reman, and I don't see sign of the black pins at the ficm so I would assume its in the injector or pigtail but it it's gutless I mean horrible and it just seems to me like it would be more then 1 injector causing issues, but the biggest issues is the 4x4 and constant beeping, when it does it I have no odometer or anything, sometimes when I hit a bump it comes back,
jmccart is offline
post #5 of 6 Old 03-30-2013, 06:48 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
instrument clusters are a known problem in these trucks too
post #6 of 6 Old 03-30-2013, 06:51 AM Thread Starter
Yea I've heard that, ford says it has to be programmed, can I swap cluster in to try or do they have to program it?
jmccart is offline
