Any thoughts would be appreciated..... - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-28-2013, 01:49 PM Thread Starter
Hi guys, im new here. '05 F350 5-speed. A few weeks ago I was driving down the road and the truck just shut off and wouldn't restart, so I had it towed home and it still wouldn't start. I unhooked the batteries and let it sit over night went out the next day and hooked them back up, low and behold it started rite up. It ran rough(which was what was usual since i didnt realized at the time the FICM was bad) but still idled and ran, I revved it up 2 or 3 times and on the last time it just shut off like I had turned off the key, then wouldnt restart. So after doing some testing and finding out the my FICM wasnt putting out the rite voltages I sent it to FICMrepair.com and had it fixed. It came back, I tried starting and still no start, so I went to what seemed to be the next common issues the IPR and the STC fitting, the screen was broke on my IPR, so I replaced the IPR. I replaced the STC fitting which was loose but not falling apart. Then after putting everything back together I hit the key and It fired up, took some cranking but I attributed that to having so much taken apart and things needing to get primed back up. Then I revved it up a couple time and low and behold it shut off again and wouldnt restart. So could anyone give me any ideas of were to look from here? Thanks
mrader89 is offline
post #2 of 2 Old 03-29-2013, 06:58 PM
ps_lane01's Avatar
Quoted: 3 Post(s)
Search hpo leak or hpop leak or ipr vs icp and that should solve your issues... Whats ur icp, ipr, fuel pressure readings?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
