replaced fuel pump ran but now no start - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-27-2013, 03:41 PM Thread Starter
I replaced the fuel pump and it ran for about 5 minutes then died. It will crank but not start. Replaced both filters using wix filters. I have fuel on the top mount filter. Its on an 03 6.0. Any thoughts or ideas?
04-6.0stroker is offline
post #2 of 10 Old 03-27-2013, 04:38 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
What is your fuel pressure? Is your pump running when you go KOEO? Maybe you have a connector or wiring problem? Codes? I would hate to think you had a new problem show up just as you fixed (or did you) this one!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 10 Old 03-27-2013, 06:27 PM Thread Starter
Well we dont have whats required to do pressure tests at our shop but what do you mean by koeo?
post #4 of 10 Old 03-27-2013, 09:46 PM
Quoted: 47 Post(s)
KOEO - key on engine off. The pump runs for about 20 seconds with the key on but not started. You can hear it. Do a search for fuel pressure units. You need a M12x1.5mm to 1/8' NPT (or whatever you need) to make the connection to the test port. Having a method to monitor fuel pressure is almost a must have. However, for higher performance applications or trouble shooting it is a must have. You could easily make one for about $20. If you wanted to digitize it for a dash gauge, it would run you about $50-$100.
Frank
Working for Toys
post #5 of 10 Old 03-28-2013, 03:09 PM Thread Starter
I have also read that it could be the ficm my guess is its that butnot sure
post #6 of 10 Old 03-28-2013, 04:19 PM
Quoted: 47 Post(s)
I have also read that it could be the ficm my guess is its that but not sure
It certainly could be, but was the issue there before you thought you had a fuel problem? You could check the voltage KOEO and while cranking. It is real easy to do with a monitor. With a voltmeter you can check the pins in the FICM inspection window for 48v. Just don't short it out! As well, sometimes it craps out once the board gets warm, if the solder connections are bad.
There are lots of potential reasons for your problem, with a more information or even a scan/diagnosis you can get into fixing it rather that guessing what's wrong.
Frank
Working for Toys
post #7 of 10 Old 03-29-2013, 03:46 PM
southend's Avatar
What happened to your truck for you to replace the fuel pump? Read the stickies on monitoring. I would suggest motorcraft or racor filters only, with oem caps. A stated you need to verify fuel pressure. Without a monitor, you will have a difficult time sorting this out. You can pick up a scanguage II at autozone for $160.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #8 of 10 Old 03-29-2013, 03:53 PM
tryed wix once and found the bottom filter did not fit and thus does not work use only eom filters
DieselFord is offline
post #9 of 10 Old 03-29-2013, 04:37 PM
southend's Avatar
This^^^^..........make sure you have oem caps to match the fuel and oil filters. Watch the videos..... http://www.dieselfiltersonline.com/f...k-filters.aspx
southend is offline
post #10 of 10 Old 03-29-2013, 06:37 PM
Originally Posted by southend View Post
sold purchased new 2007 oil + factory oem filter at 5k fuel oem filters at 10k trany oil + filters at 30k note have the 08 pan and filter
the op has a issue related to a wix filters
