Need help 6.0 won't start and stranded - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-26-2013, 02:55 PM Thread Starter
I have never had a start problem. Truck fired up fine, then I stopped a few minutes later. Turned the truck off and when I went to start it would not turn over. Turned the key like normal and waited for glow plug light to go off and the truck did not even attempt to start. Tried taking out of park and put I other years and no change. All lights and radio come on but doesn't make an attempt to start.
If it sounds like a fuse does anyone know which one would likely be the culprit and if not what else I should look at thanks in advance.
xmas is offline
post #2 of 12 Old 03-26-2013, 05:00 PM Thread Starter
Anything??? I know this is quick but I could use really use some help.
xmas is offline
post #3 of 12 Old 03-26-2013, 05:24 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
What is your voltage reading on the batteries? Sounds like a bad battery, just because your lights come on and all your accessories work does not mean you don't have a bad battery. You need I think at least 24v 1500 cranking amps just to spin the starter. My suggestion is load test batteries and have alternator tested. Do not attempt to start the truck until you know the condition if the batteries, you could take out the ficm if you are not careful. Good luck
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 12 Old 03-26-2013, 05:28 PM Thread Starter
I didn't think the battery only because everything was working normal a few minutes earlier and then just nothing. I will pull the batteries tomorrow and get them tested. Can anyone think of any other relatively common issues that I should check out before having towed.
Thanks for the reply
xmas is offline
post #5 of 12 Old 03-26-2013, 05:44 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Its not a 24 volt system it is 2 12 volt batteries in parallel
thank you to Berusch for advising me of my mistake!!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 12 Old 03-26-2013, 05:46 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
call me i sent you pm
A/C ASW A/W WINGS
post #7 of 12 Old 03-27-2013, 04:06 PM Thread Starter
A big thanks to Jugernaut for a quick response and great advice that resulted in me driving away. Tough to find people that go out of there way to help someone out.
THANKS AGAIN TO JUGERNAUT AND THE .ORG
xmas is offline
post #8 of 12 Old 03-27-2013, 04:24 PM
Originally Posted by JUGERNAUT View Post
Its not a 24 volt system it is 2 12 volt batteries in series
It's (2) 12V batteries in *parallel*
Overly simplified:
Identical batteries in parallel = same voltage, double current (all things being equal)
Identical batteries in series = double voltage, same current (all things being equal)
berusch is offline
post #9 of 12 Old 03-27-2013, 04:37 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Overly simplified:
Ohhh my god my bad!!! im getting old ill correct it!!! you think one thing and type the other soon ill be walking into walls!!!
A/C ASW A/W WINGS
post #10 of 12 Old 03-27-2013, 04:40 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Xmas you are welcome!!
A/C ASW A/W WINGS
