Low on power and terrible mileage after Rev X Booster? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-25-2013, 12:14 PM Thread Starter
Quoted: 4 Post(s)
Hey Guys-
I recently noticed a dramatic loss of power, and terrible MPG. I just had my turbo replaced with the Garret powermax about a month ago, fresh oil change, fresh fuel filters, clean air filter. The only thing that I did do weas add some Rev X Booster in the previous tank. Is it possible this has affected something in the fuel system negatively? My last tank I netted about 10mpg driving freeway.
Assuming it's just a coincidence, what are the next logical steps to diagnose? Currently there are no codes, FICM is 48.5-50 volts via my SCT Livewire. Batteries are 13.5v, engine coolant temp and oil temp never see more than 8-10 degree delta. What else should I be monitoring to help narrow down the issue? At this point, if I have a stock tune in, I have to mash the peddle just to get to a reasonable cruising speed on the freeway unloaded.
Mods:
2007 F-250 4x4 w/55k miles
AFE Intake
Garret Powermax Turbo
SCT Livewire with both innovative and Vivians tunes (currently stock while diagnosing)
4" Turbo back exhaust (no cat)
mmlx89 is offline
post #2 of 5 Old 03-25-2013, 01:05 PM
garbonzo1991gt's Avatar
Check your boots on the intercooler pipes... More than likely one of them is cracked.
05 F250 "Tow pig"
Mods: A little bit of this and that.
garbonzo1991gt is offline
post #3 of 5 Old 03-25-2013, 01:08 PM Thread Starter
Quoted: 4 Post(s)
I pulled them all off and cleaned them about 3 weeks ago, they looked to be in great shape then. I will check them again to be sure. Again, the truck only has 55k miles on it, so I haven't seen too many items that show much visual wear.
mmlx89 is offline
post #4 of 5 Old 03-27-2013, 07:26 AM
ps_lane01's Avatar
Quoted: 10 Post(s)
What is the boost like in stock tune? Very slow to build boost, any smoke, whats your fuel pressure?
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #5 of 5 Old 03-27-2013, 12:38 PM Thread Starter
Quoted: 4 Post(s)
Builds boost off idle just fine, no smoke, and unsure of Fuel Pressure. It feels like it makes decent power off idle, then it's just flat. The turbo has about 500 miles on it, so I am leaning towards fuel system issue. I am dropping it off at the dealer today to have them diagnose.
mmlx89 is offline
