High Speed Vibration - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-25-2013, 11:07 AM Thread Starter
My 05 F250 has a vibration when going down the Hwy. I checked and found the U joint at the front of the rear drive shaft had some play in it. Would that alone cause the vibration or would it take more then that like maybe the bearing support in the center of the truck
towboat is offline
post #2 of 6 Old 03-25-2013, 12:26 PM
southend's Avatar
Re: High Speed Vibration
That would probably do it alone.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 6 Old 03-25-2013, 12:51 PM
asian195's Avatar
Quoted: 2 Post(s)
bad u joints can cause vibes. Replace those and see if it stops. If it continues, check your trans mount, then carrier bearing.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 6 Old 03-27-2013, 05:47 AM Thread Starter
I replaced both u joints on the rear shaft and still have a vibrations at Hwy. speed. I looked at the tranny (tried to move it around) and carrier bearing and theres no noticable sign of wear or movement. Checked both rear tires pressure, even swithed them ! still feel a vibration at the rear of the truck.
towboat is offline
post #5 of 6 Old 03-28-2013, 03:28 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Had problem like that on my 7.3 turned out to be rear axle bearing
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #6 of 6 Old 03-29-2013, 09:59 PM
I had a vibration that was very noticeable at a certain speed, I think it was 40-50mph. I tried everything, and finally found a balance weight was gone off the driveshaft.
Does it continue to vibrate if you get up to speed (try it going down a very long hill) and then pop it into neutral?
cappybye is offline
