Reving up then idling rough - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-20-2013, 08:05 PM Thread Starter
I did a search but couldn't find what I was looking for.
I have a 04 f350 all stoke except for a 5" exhaust. 108k miles
The other day I was driving through town and it was running fine the it started to accelerate on its owe I let off the peddle but it stayed at about 1000 rpms for a sec. Then it started idling rough. I changed the fuel filters and it seemed to help but then it did it again today while at a fast food drive through idled up for a sec then ran rough then it died. But started right back up. But idled rough all the way home. About a hour later I went out and it started up fine it ran fine for about 10 mins then started to do it again.
Any clue?
Thanks.
phil.d.n. is offline
post #2 of 8 Old 03-25-2013, 05:27 PM Thread Starter
I ran the codes on my truck and all I got was P2285
Injector control pressure sensor
Circuit low.
Could this be causing my unusual problem?
post #3 of 8 Old 03-25-2013, 06:18 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Circuit low.
YES check your icp sensor if it has oil in the plug you need to replace the sensor and plug. Is it a early 04 or late?
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #4 of 8 Old 03-26-2013, 03:13 PM Thread Starter
I'm not sure. How do I tell?
post #5 of 8 Old 03-26-2013, 06:41 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
I'm sorry i didn't get back sooner early 04 still has icp and ipr together in the back! late 04 has icp on passenger side valve cover.
A/C ASW A/W WINGS
post #6 of 8 Old 03-27-2013, 05:18 PM Thread Starter
Does this make a difference in the sensor I buy? Or just the difficulty in changing it?
post #7 of 8 Old 03-27-2013, 05:44 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Yes the sensor in the rear is different from the one on the valve cover
A/C ASW A/W WINGS
post #8 of 8 Old 03-27-2013, 05:48 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Under turbo use 3C3Z-9F838-EA. Right valve cover use 4C3Z-9F838-A.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
