Replace Injector Seals? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-20-2013, 07:43 AM Thread Starter
Quoted: 3 Post(s)
I'm having an occasional hard start, and I definately have a stiction issue. I'm going to do some injector/oil rail maintenance in the next week or two and I'm looking for some advice as I get ready.
I'm going to pull the injectors and replace the o-rings and copper washers, pull the spool valves and clean them with 600 grit to get rid of stiction, and replace standpipes and dummy plugs.
My question:
Should I replace the injector seals too? I haven't heard of them going bad, and I know sometimes pulling everything apart I can cause more problems than I started with.
Any advice is much appreciated!
I'll keep you all posted as to whether or not this solves my occasional hard start problem.
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #2 of 5 Old 03-21-2013, 08:52 AM Thread Starter
Quoted: 3 Post(s)
Clarification
Should have been more clear...
The seals I am wondering if I should replace are the high pressure oil seals for the injector. Here's a picture:
http://www.thedieselstore.com/templa...Num=APPAP0002#
I'm talking about the seal labeled "B" in the second image.
Thanks!
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Zoodad Mod
fuzzman is offline
post #3 of 5 Old 03-21-2013, 11:03 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
A few years ago it was nearly impossible to get those seals. If they look damaged (abrasions, cracks or lines) replace them. It isn't absolutely required, but if you got them, why not freshen them all up.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 5 Old 03-21-2013, 11:25 AM Thread Starter
Quoted: 3 Post(s)
Thanks Twicebergs By the way I'm taking a cue from the link in your signature to clean my spool valves. Thanks for posting that, it's what finally got me off my duff.
By the way, I can't get that sucker to play from your link. But I got enough info to go find it on YouTube.
Take Care
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Zoodad Mod
fuzzman is offline
post #5 of 5 Old 03-21-2013, 01:18 PM
Quoted: 47 Post(s)
Just checked all the links to videos and all play fine.
Frank
Working for Toys
