Goodbye turbo? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-19-2013, 03:19 PM Thread Starter
Goodbye turbo?
Not sure what happened... coming home from work today and as I reached the top of a hill I heard a loud pop. Following this, the turbo sounded completely different - more of a whine than whistle...(stock 03 vgt) No smoke of any kind. Just changed oil and I can't see any fluids puking or leaking. I limped it home and I feel a tremendous loss of power ie: no boost (guessing as I dont have gauges). Maybe too much boost and it just popped? I haven't a clue... I was sitting around 2-2.5k rpm when it popped. Not sure what to do at this point. A Powermax may be in my future...
Ronin114 is offline
post #2 of 19 Old 03-19-2013, 03:23 PM
rdaffin's Avatar
Re: Goodbye turbo?
Sounds more like it popped a boot off. Check the IC boots before you write off the turbo!
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #3 of 19 Old 03-19-2013, 03:36 PM Thread Starter
Wow... don't I feel dumb. The cold side boot popped off. Thanks so much for the help. Do I just reattach the thing? I read somewhere to use hairspray?
Ronin114 is offline
post #4 of 19 Old 03-19-2013, 03:42 PM
06Lariat_'s Avatar
Just clean the fittings good I've heard about the hairspray thing but never had to do it.
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #5 of 19 Old 03-19-2013, 04:38 PM Thread Starter
Got everything off but one of the clamps is history... are these clamps special or can i use anything that will fit? I'm thinking about double clamping it anyway..
Ronin114 is offline
post #6 of 19 Old 03-19-2013, 05:54 PM
dnf12908's Avatar
Quoted: 35 Post(s)
The hairspray fix is a good one. I highly recommend it. You don't have to over-tighten your clamp and you'll have peace of mind that the boots will not blow off. Make sure the boots and turbo/pipe connections are clean and dry before you use the hairspray.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Edge Insight monitor
Harley headlights w/Gensii LED bulbs
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #7 of 19 Old 03-19-2013, 07:52 PM Thread Starter
I ended up using an oddball clamp I found in the garage. It doesn't have a spring otherwise it is exactly the same. Does anyone have a part number or a place where I can purchase just the clamp (other than the stealership)? I would like to replace the current clamp with an oem one asap as I dont trust it...
Ronin114 is offline
post #8 of 19 Old 03-19-2013, 09:16 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Glad it turned out to be a simple fix, and not a new turbo!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #9 of 19 Old 03-20-2013, 08:50 AM
Quoted: 3 Post(s)
clamp
I get my parts from Tousley Ford on-line. Great prices!
Your boot probably popped off because of oil from your Crank Case Vent. Oil tends to saturate these boots and sometimes they are rendered useless because of it. If it happens again I'd replace the boots, and maybe look into a CCV reroute. Search around the forum and you will learn about the CCV reroute, it's a simple fix to reroute the air from the crankcase vent through a filter to catch the oil before it enters your turbo.
Glad you're back running!
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #10 of 19 Old 03-20-2013, 08:33 PM
dnf12908's Avatar
Quoted: 35 Post(s)
The CCV reroute might not be a good idea. I think I read on here that the CCV is designed to put vacuum on the oil control piston rings to prevent blow-by. Without the CCV there could be a smoking issue at idle.
Darrell
EGR delete
ARP studs
OEM gaskets
FPR (blue spring)
stator delete
dnf12908 is offline
Tags
6.0 , boost , no power , turbo , vgt
