Crazy Vibration Need Help ASAP - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-19-2013, 12:04 PM Thread Starter
Exclamation Crazy Vibration Need Help ASAP
I have a 2003 F250 4x4 with about 240k miles on it completely stock. It seems to run fine, but when i am driving on the interstate and get up to about 65mph + it seems like there is a vibration in the front end and cannot figure out what it is coming from. Here is the weird part it only vibrated when i am going 65mph+ while i am giving it gas. As soon as i let off the gas the vibration goes away even if the truck is still going over 65mph. I just replaced the wheel bearings so that shouldn't be an issue. Any help would be greatly appreciated. I would hate to have to take it to a dealer but i am taking a trip at the end of the month and need to figure it out by then. Thanks an advance for any advice.
tarzanmonkeyman is offline
post #2 of 6 Old 03-21-2013, 07:31 AM Thread Starter
Please help
post #3 of 6 Old 03-21-2013, 07:48 AM
Quoted: 39 Post(s)
Rear Carrier bearing and\or rear ujoints.
2015 CCSB F-250 4x4 6.7 diesel lariat, 24k miles
Carli 2.5in lift Coilover triple bypass system (Dan's old kit), full rear deavers, carli radius arms, raceline clutch 17in,rims, toyo RT 37in tires, vision X 40in light bar, Rigid Q2 driving pattern, rigid DOT fogs
Jomax is offline
post #4 of 6 Old 03-21-2013, 08:35 AM Thread Starter
Rear carrier bearing? I'm not to sure I know exactly what that is.
post #5 of 6 Old 03-21-2013, 08:39 AM
Quoted: 39 Post(s)
Is your truck a Long bed? If it is you have a two piece driveshaft. Where the two pieces meet in the center there is a bearing. That is the carrier bearing
Jomax is offline
post #6 of 6 Old 03-21-2013, 10:37 AM Thread Starter
Ok yes it is a long bed I will check that as well.
