HELP Please - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-17-2013, 01:08 PM Thread Starter
jsbowlin's Avatar
HELP Please
Let me start first with, I CAN NOT BELIEVE I DID THIS!!!!!!
While starting to put my truck back together after doing head gaskets and studs, I was updating the stc fitting in the high pressure oil pump. I was getting the 2 o-rings out. Got the small black one out but while getting the yellow bigger one out it flipped and went right down the back of the engine where the gear that the pump runs off of. I have tried to fish it out. Taken a shop vac and made a small hose to run down there, no luck.....
Please, could some one go a head and just rip my a$$ and beat me with a bat. Afterwords could you tell me what or how am I going to fix this grand f$&k up. Please I'm just sick over this. Help
2006 f250 Lariat White FX4
4" exaust turbo back 6" tip
EGR delete
FICM by Ed w/Atlas 40
Edge Evolution for Monitoring
SCT Programmer
Blue Spring upgrade
6.4l Banjo Bolts
Studed
Leveled 35" Nitto Trail Grapplers
jsbowlin is offline
post #2 of 6 Old 03-20-2013, 09:22 AM
Quoted: 3 Post(s)
Dang!
That sucks!
Maybe find a bore scope you can use? Hopefully someone chimes in here, I feel your pain!
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #3 of 6 Old 03-20-2013, 02:21 PM
Since it is a rubber o-ring the gears should chew it up with no harm. Since it is the bigger 0-ring I would recomend pulling the FICM fuse and bumping the motor over a few times to give it time to chew.
Odds are it dropped all the way to the pan but no guarrenty. If really worried pull the pan.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 6 Old 03-20-2013, 04:39 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
just be glad it wasn't a STC bolt.
I can't really think of anything an o-ring would do. Being it is large enough it will probably just settle in the bottom of the pan. As long as it doesnt get too ground up the pick up tube won't ever be able to pass it into the oiling system.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 6 Old 03-23-2013, 11:50 AM
Rivan's Avatar
HELP Please
Dude!...that's totally BALLS!
Everyone should learn a valuable lesson from this (I know I am) and that's the importance of stuffing some tags into exposed opening to avoid things and debris from getting in there.
Wish you luck on getting out... I know I would keep trying because I wouldn't feel good about hoping its ok with leaving it in there
Rivan is offline
post #6 of 6 Old 03-23-2013, 11:51 AM
Rivan's Avatar
HELP Please
Everyone should learn a valuable lesson from this (I know I am) and that's the importance of stuffing some rags into exposed opening to avoid things and debris from getting in there.
Rivan is offline
