What's the possible issue? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 03-16-2013, 01:51 PM Thread Starter
2006 f-350 with 6.0l was driven 550 miles on the highway and took 3 gallons of water in. We done a radiator pressure test to check for external leaks. No leaks found. We then released the pressure and let the truck run a while. If the gauge is accurate it got to 20 PSI. Under quick throttle it would bump 21 PSI. What may be the issue or what are some further diagnostics I can do? It was also puking some under quick acceleration while driving.
sbcauto2012 is offline
post #2 of 33 Old 03-16-2013, 02:48 PM
PHYRMN's Avatar
Hate to say it, but headgaskets are in your very near future. Its got all the signs.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 33 Old 03-16-2013, 03:05 PM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
blowing white smoke? could either be the EGR cooler or headgaskets.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 33 Old 03-16-2013, 03:37 PM Thread Starter
It's not blowing any white smoke. Motor runs great, just drinking water.
post #5 of 33 Old 03-16-2013, 03:51 PM
PHYRMN's Avatar
Most likely from the puking when going down the road. Losing that much coolant with no signs of it in the exhaust and no visible leaks, would lead me back to the excessive puking.
PHYRMN is offline
post #6 of 33 Old 03-16-2013, 03:54 PM
PHYRMN's Avatar
Typical coolant pressure should be around 6 - 10 psi.
PHYRMN is offline
post #7 of 33 Old 03-16-2013, 03:55 PM Thread Starter
What would cause the excessive puking and pressure?
post #8 of 33 Old 03-16-2013, 04:05 PM
PHYRMN's Avatar
Like the previous post reply, its looks like a failed EGR Cooler or headgaskets. Pull your EGR valve and see if its wet on the valve. That will tell if its the EGR Cooler. If its dry, then its most like head gaskets.
PHYRMN is offline
post #9 of 33 Old 03-16-2013, 04:06 PM
PHYRMN's Avatar
I have heard of heater cores leaking, check there too. But with the excessive puking and coolant pressure I would put my money on headgaskets.
PHYRMN is offline
post #10 of 33 Old 03-16-2013, 05:07 PM Thread Starter
Where is the EGR valve located?
