no heat - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-16-2013, 05:30 AM Thread Starter
no heat
hey guys my 04 6.0 has no heat while driving and at idle coolant levels are the same and do not change.
i just changed the water pump last week and did not change anything still the same with no heat. i did check the lines to the heater core one line hot and the other is cold. does that mean that the heater core is clogged? also will a flush with vc-9 help?
also how can i verify that my blend door is operating correctly? when i was checking the heater core line i playing the controls and it seemed to work i saw the actuator arm moving. not sure if that is the correct to know if its working or not.
Its neither good nor bad, only thinking it makes it good or bad.
UserError is offline
post #2 of 4 Old 03-16-2013, 07:24 AM
Diesel is Power!!!
bigmic's Avatar
Quoted: 4 Post(s)
The vacuum line that controls the flow to the heater core could have came off. Follow the heater hose, there is a control valve. There should be a vacuum line attached to it. This shuts off the the flow when the air condition is on. With out vacuum the valve won't open to allow heat to the heater core.
06 CC 4X4 King Ranch
225k + miles
Reman Motor @ 173K (Problem existed b4 I bought it)
SCT Dash Scan
SCT Livewire/EGT Kit
TSD SPD and TDP Extreme tuned
Glowshift Fuel Gauge
ARP Studs
FelPro Head Gaskets
Warren 155cc/stock injectors
Cat Delete
EGR Delete
Update STC fitting
Blue Fuel Spring
New oil cooler
New Turbo
Updated Dummy Plugs &
Stand Pipes
Sinister Coolant Filter
ELC Coolant
bigmic is offline
post #3 of 4 Old 03-16-2013, 07:49 AM
How much coolant came out? Only reason is when I did some work to my truck the heater didn't want to work until I worked some air out of the system. Probably doesn't happen a lot or I did not so something right.
<----Been here too many times.
2007 F250 Outlaw - ALL black new leather 20012, home made 4" straight pipe kicks out in front of rear tire, Sinister egr cooler and coolant filter, EDGE CS monitor, home-drilled banjo bolts, and a heavy foot.
Wants - 2.5 to 4" lift
joshoke is offline
post #4 of 4 Old 03-16-2013, 08:03 AM Thread Starter
ok i'll look into that. if the control valve is bad would cause the one line to be hot on the heater core and the other line to be cold?
i used a air lift to create a vacuum in the cooling system. i think 3 1/2 gallon came out.
