2003 Fuel Pump Vs 2006 Fuel Pump question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-15-2013, 05:57 PM Thread Starter
Sno-Mow's Avatar
So on my 2003 my fuel pump took a s**t last night. I talked to a buddy that has a couple 6.0's he's parting out and he had a good fuel pump out of a 2006.
I picked it up from him today and pulled the old one...
The old one has 3 plugs on it and the 06 one has 2...I thought about putting the cover from my pump which has the extra plug and putting it on the 06 pump. Any ideas if this will work?
Also when I pulled the cover off the side of my 03 pump I found metal shavings in it
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #2 of 3 Old 03-15-2013, 06:06 PM Thread Starter
Sno-Mow's Avatar
Is this the circular end of the pump that actually goes bad? Can I just swap these on those pumps?
https://www.commonwealthdiesel.com/i...roducts_id=458
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #3 of 3 Old 03-16-2013, 09:30 AM
Powerstroke Techie
Quoted: 14 Post(s)
Garage
Feedback Score: 4 reviews
You'd be better off with the 06 pump. 03-04 had a fuel heater in the side cover that would occassionally short out from water in the seperator and blow a pretty critical fuse. Later trucks came without a fuel heater and a new jumper harness that deleted the plug. You'd be fine just taping off the plug
it would be wise to open up the 06 pump on the bench to make sure it's clean inside and no metal particules floating around in there
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
