Runs like crap unless I plug it in? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-15-2013, 05:42 AM Thread Starter
Garage
K guys here's another one my pickup starts and runs fine if I plug it in if I don't it runs rough and sounds like we are only running on half the cylinders it's getting 70 degrees during the day and I still have to plug it in at work! Changed glow plugs. Code reader reads no codes ?? I'm lost. Help!!!!!!
Mangum is offline
post #2 of 6 Old 03-15-2013, 06:43 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Re: Runs like crap unless I plug it in?
Stiction...see twoicebergs thread on fixing stiction. Mine was doing the same thing till I fixed the stiction and that was 2 years ago.
Sent from AutoGuide.com App
toren302 is online now
post #3 of 6 Old 03-15-2013, 07:00 AM Thread Starter
Garage
I'm a dumb newbie where do I find his thread
Mangum is offline
post #4 of 6 Old 03-15-2013, 07:51 AM
Bump To Pass!!
toren302's Avatar
Its in the general 6.0 section. Tittled Fixing Stiction. If you haven't turned a lot of wrenches on a 6.0 then you could try some rev-x or archoil 9100. Usally tuose clear it up. Cleaning the spool valves is a longer term fix.
post #5 of 6 Old 03-15-2013, 08:15 AM
strokethis04's Avatar
Quoted: 3 Post(s)
Mine old 6.0 was like that it ended up being the ficm had low volts
2004 f-350 cc 6.0l
afe stage 2
4in magnaflow
sct with looney from dj
6 inch lift
33x15.5 mt atz
16x10 raceline renegads
zoodad
auto meter gauges
strokethis04 is offline
post #6 of 6 Old 03-15-2013, 08:22 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Here it is.
Fixing stiction
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
