Diagnostic Codes - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-13-2013, 01:22 PM Thread Starter
Quoted: 4 Post(s)
Diagnostic Codes
I have recently purchased a Scangauge II to use with my 6.0 after the loss of 8 injectors. Well I'm just getting a hang of the device and I had a few questions on diagnostics. In order for codes to be transmitted must you have a check engine light that works? Mine doesn't really work and I would like to know if it is necessary. Another thing is what type of issues would it pick up (ie misfires etc).
And finally this is a little unrelated to the topic but what X-gauges should I customize? I already have FICM voltage, ICP, and Oil Temp.
Also I know I post alot but I'm new to a diesel and this is my first vehicle ever. (My dad brought it home for me, I wanted a 7.3 but we get discounts at that particular dealership and all they had at the time was a 6.0)
joejack6.0 is offline
post #2 of 15 Old 03-14-2013, 05:30 AM
A dealership sold you a vehicle with a malfunctioning check engine light...????
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 15 Old 03-14-2013, 06:52 AM
"codes to be transmitted" ? Not sure what that means, so putting the post aside, here is a brief semi-detailed summary of a PCM/ECM and the logging and lighting, it does.
The PCM/ECM is the computer that lights the check engine light. Think of the PCM/ECM as the windows computer that runs the truck. Along with running the truck(fuel, air, timing etc...shifting, cooling, etc...etc...) it monitors certain parameters of the truck. Temperatures, knocking, mis-fires and a host of other stuff. If a monitored parameter is out of tolerance, then a code is stored in memory. This code is defined as, and is, applicable to the parameter that was out of tolerance. If the code set in memory, due to the out of tolerance condition, is emmisions related then the PCM/ECM turns on the check engine/service engine (CEL/SEL) light. If a mis-fire is detected the light often is programmed to blink. So, does that help any?
As a side note, you need to find out what's wrong with the truck 'cause 8 injectors don't just fail for no reason. Even on our beloved 6.oh's.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #4 of 15 Old 03-14-2013, 05:58 PM Thread Starter
Quoted: 4 Post(s)
Actually it does help somewhat. What caused the injectors to go bad was a bad fuel pump causing bad fuel pressure. It was going bad for awhile we (as in my mechanic and I) think. Back in December on a routine service trip they detected a bad injector (number 1 I believe it was not sure on that). I replaced it and it ran alot better for awhile. Less than 2 months later my truck would die on me everytime I put it in gear and I'd have to warm it up for a good 20 minutes before it would run properly and I noticed I didn't have much power. Well one day it began doing it alot more and when it was in park. So I took it to the dealership and they said its fuel pump was bad. They tested it and the fuel pressure still wasn't normal. So they looked at the injectors and saw that each of them had been damaged. They didn't really misfire they were just junk so I would understand why a check engine light wouldn't come on. But in December no check engine light came on so maybe the incidents were related. Anyway all is well now except for a slight miss after a cold start (no codes for that I would think). Bought the scangauge to moniter my FICM voltage and all is normal.
Thanks for your information!!
Ps. What did you mean when you said knocking?
post #5 of 15 Old 03-14-2013, 06:35 PM Thread Starter
Quoted: 4 Post(s)
MikeB
Well I'm not sure if it works or not. When I turn my key to cycle my glow plugs it appears until I fire the engine up. Other than that it doesn't do anything. Is there a way I can test it? Or get it fixed if it doesn't work? It never illuminates if I have a miss on a cold morning so I'm curious if that is normal or does it illuminate after the problem has gone on for awhile.
post #6 of 15 Old 03-14-2013, 06:52 PM
Diagnostic Codes
Cel is not gonna come on for a misfire cold on a 6.0. If it comes on when key is turned on and goes out it is working correctly. Cel comes on for emission related codes basically.
chris7686 is offline
post #7 of 15 Old 03-14-2013, 07:29 PM Thread Starter
Quoted: 4 Post(s)
Ok thank you!! The problems I've had are all starting to make since now! Low fuel pressure caused bad injectors. Not misfires! I just need some fuel pressure gauges. Any idea on where to purchase them?
post #8 of 15 Old 03-15-2013, 06:34 AM
I would keep looking. Mostly at the FICM. A FICM going south can cause poor cold starts, and will cause injectors to fail. Low fuel pressure can harm injectors also, but usually an injector harmed by low fuel pressure is REALLY harmed. Low pressure doesn't fill the injector well and when the high pressure oil is appliedto the plunger it can/will buttom out(because of the lack of anything/enough to pump) and REALLY really can destroy injectors. Injectors harmed by low pressure usually don't go much further down the road.
A failing FICm, on the other hand, will keep going AS it slowly kills the injectors. Plus will give a rough cold start.
post #9 of 15 Old 03-15-2013, 07:47 AM Thread Starter
Quoted: 4 Post(s)
What should I look for on my FICM? I continue to moniter my voltage and it is 47v-48v which is normal.
post #10 of 15 Old 03-15-2013, 08:00 AM
I'm not totally convinced that the monitored voltage is the actual actual voltage, as measured with a meter. Search this site, or the web, for FICM checking" and you'll find a write up on measuring the actual output(input) of the P/S half of the FICM with a meter. But, if it's really 47-48 you should be good. Checked when cold, not running etc...?
