Degas Cap small coolant leak - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-11-2013, 04:56 PM Thread Starter
I have been having just a very small coolant leak coming from the degas cap. I have the egr delete and the oil cooler was replaced. I was wondering if it could be just the cap or something possibly bigger. Truck is all stock but the egr delete and oil cooler. It has 142,000 miles and doesnt tow anything. Thanks
GOGATORS is offline
post #2 of 2 Old 03-11-2013, 05:03 PM
JustinOOO9's Avatar
Quoted: 583 Post(s)
Garage
do you have any guages to monitor your engine coolant temp and engine oil temp. make sure they're not more then 15 degrees apart while cruising around 70 mph.
or you can fabricate your own pressure test.
put a t split in your overfill hose. the run closest to your cap. and attach a mechanical boost guage with no more then 30 or so and make sure you dont build pressure super fast.
others will chime in.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
