Coolant bottle leaking - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-09-2013, 06:44 PM Thread Starter
I have an 06 ford f350 had no coolant problems now coolant was puking out of cap. Replaced the coolant bottle and cap same thing only happens when I press pedal to go faster people told me its my oil cooler clogged up no loss in power need help
Sent from AutoGuide.com App
Welder361 is offline
post #2 of 5 Old 03-10-2013, 08:27 AM
PHYRMN's Avatar
If your degas bottle is over pressurizing, thats usually a pre-sign, symptom of leaking headgaskets. Engine combustion gases are leaking by the head gaskets or through cracks in the head allowing those gases to enter the cooling system. This over pressurizes the cooling system causing the degas bottle cap to vent. When the cap vents it allows coolant to escape also.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #3 of 5 Old 03-10-2013, 08:31 AM
PHYRMN's Avatar
Also, Ford modified the MIN-MAX coolant level. The new MAX level is the old MIN level. That makes it around 1" from the bottom of the front of the degas bottle.
PHYRMN is offline
post #4 of 5 Old 03-10-2013, 04:26 PM Thread Starter
So that's what I'm doing wrong I filling it to max. I put it on min and when I drive it should go up?
post #5 of 5 Old 03-10-2013, 06:24 PM
PHYRMN's Avatar
If your degas bottle is holding the correct pressure the coolant level shouldn't move much at all. The bottle holding pressure will keep the coolant from expanding, to a certain extent. Ford changed the coolant level because of the puking issues, and the weak caps, they upgraded the caps and kept the lower coolant level.
PHYRMN is offline
