Speedometer not working on 06 F250 after cleaning engine - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-09-2013, 03:54 PM Thread Starter
OK. Pressure washed my truck. Probably got a little carried away with the water. Long story short, ended up with about a dozen different codes and a truck that wouldn't start. Opened up all the connectors that I could find under the hood and used compressed air to dry them out. Used electrical grease to keep them water tight. Everything works great, but now my speedometer doesn't work. I've checked and cleaned the unit on the transmission. I also have an Edge CS and it doesn't show the speed either. I was getting a VSS error til I cleaned and dried the transmission unit. Now no errors and no speedo...
iHenry is offline
post #2 of 10 Old 03-10-2013, 04:16 AM
You may have blew a fuse
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 10 Old 03-10-2013, 03:19 PM
06Lariat_'s Avatar
Check fuses and next time stay away from the electrical parts lol
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #4 of 10 Old 03-10-2013, 05:46 PM Thread Starter
Speedo problems
Any particular fuse? I can't find anything bad. Wondering if it is possible to have shorted the transmission unit out. Did find water in one connection and once I cleaned and dried it, everything started working again, except the speedo...
iHenry is offline
post #5 of 10 Old 03-14-2013, 08:06 PM Thread Starter
Bad ABS module
New update. Took my truck to the Ford dealership today and was told the following;
"Self Test P0500 in multiple modules. Checked rear axle speed sensor input to ABS module OK No output to other modules. Faulty ABS module."
Here's my question. If I get another ABS module, is this going to be a simple plug in operation? I found one off a truck of the same year, with all the same options. Can I just plug it in or does it have to be programmed?
BTW - This weekend, I'm going to take the electronic portion off and clean it with electronics cleaner, make sure it's dry and put it back together. Is that doesn't work, the plan is to order a replacement. $700 though Ford or a used one of $100.
iHenry is offline
post #6 of 10 Old 03-20-2013, 06:03 PM Thread Starter
Speedo update
OK. Purchased an ABS module from B and R Auto Wrecking on eBay and swapped the module on their unit for the one on mine. Got into my truck and turned the key to the on position. The ABS light immediately came on. Undeterred, I went for a short drive. My speedometer works, but the ABS dash light is on. My ABS did appear to work, but I don't know for sure tomorrow. I'll update again tomorrow.
If anyone has any clues about clearing the ABS code, I'm all ears. Other than that, this weekend, I'll try disconnecting the batteries over night...
iHenry is offline
post #7 of 10 Old 11-21-2016, 06:32 PM
Dante04SRT's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Any resolution to this? How much was the ABS module?
-Brian
2005 F350 6.0 CC/SB Lariat 4x4
EGR Delete
ARP Studs
All updated Ford internals
Edge Insight CTS2
Swamp's 58V FICM
SCT X3
TGC 2.5" Level Kit
Zerex EC-1 ELC
08+ Step Tailgate
08+ All Power Mirrors (Factory Functions, too)
2011 Rear Bumper
B&W Turnover Ball
8oz Stanadyne Performance w/each fillup
Dante04SRT is offline
post #8 of 10 Old 11-25-2016, 11:17 AM Thread Starter
Yes. I purchased a used unit and installed it. Everything worked except my speedometer.
I took it into Ford and they pulled information off the old unit and pushed it to the new one and everything worked great afterwards. I spoke to the tech and he said that sometimes they have to be programed and sometimes they don't. I believe that I purchased the used unit for around $200 and it was $75 for Ford to program it. Still half what they wanted for a new one, which still would have required programing.
Since then, I've purchased AutoEnginuity and I'm curious if it could program the new one, but I haven't really look into it.
4" Turbo back exhaust, EGR update, AFE dry filter system, Amsoil Oil bypass kit, High Idle Mod
Coming soon
Blue spring update.
iHenry is offline
post #9 of 10 Old 11-25-2016, 11:54 AM
ZMANN's Avatar
Quoted: 1469 Post(s)
A/E cant program the ABS module
Other than tire size
Dis you look at your old module to see if it was waterdamaged ?
We Miss you Ronnie
ZMANN is offline
post #10 of 10 Old 12-02-2016, 11:43 PM Thread Starter
Yes. I took apart the old unit out of curiosity. I didn't see any signs of water. Prior to taking it to Ford, I actually used a non-conducted cleaner dryer and compressed air to clean out the ABS unit.
Just one of those things I guess.
iHenry is offline
Tags
speedometer problems
