White residue? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-08-2013, 06:07 AM Thread Starter
White residue?
I just bought a 2005 6.0 with egr delete and 4inch into 5 exhaust. I popped the hood the other day and found white residue on degas and a little coolant sitting around the rim of the degas. I don't have any white smoke and I have not lost any power. Oh and when I bought the truck I did not see any white residue on the degas bottle. I guess what I'm asking is is this a dead giveaway of the dreaded blown HGs? And if it is how long can I drive it like this?
Duf79 is offline
post #2 of 9 Old 03-08-2013, 06:11 AM
Koda22's Avatar
Quoted: 5 Post(s)
Might be the cap, I know that a lot of people talk about the cap goin bad, and that there is a new cap out that is ment to be better...might try that first...only bout 15 bucks and see if u get any more white stuff and go from there
Koda22 is offline
post #3 of 9 Old 03-09-2013, 06:23 AM
southend's Avatar
Re: White residue?
Make sure your coolant level is slightly below the min mark. If your head gaskets are bad, you can drive it till it hydrolocks. I don't suggest that, btw. Anotherwards, there is not a good answer for that. But plenty of people have done it, unfortunately.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 9 Old 03-09-2013, 06:28 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
Originally Posted by southend View Post
Make sure your coolant level is slightly below the min mark. If your head gaskets are bad, you can drive it till it hydrolocks. I don't suggest that, btw. In other words, there is not a good answer for that. But plenty of people have done it, unfortunately.
well it could be a damaged egr cooler and clogged oil cooler and not require head gaskets and studs quite yet... I'd replace the cap it costs between 5-15 dollars and if it fixes it your all set.. mine doesn't even puke over the "new max" line but its not much over
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #5 of 9 Old 03-10-2013, 01:39 PM Thread Starter
Thanks for your help guys but it's official the head gaskets are blown. Degas bottle is puking now with new cap and temp gauge on dash goes to hot towing my trailer up hill.
Duf79 is offline
post #6 of 9 Old 03-10-2013, 07:02 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
There is little chance of hydrolocking these engines with simply blown head gaskets as the coolant doesn't enter the cylinders. The cylinder pressures pass through the leaking gasket and pressurize the cooling system thus causing the puking. Now if he had a ruptured egr cooler then yes you most definitely can hydrolock the engine.
He has the EGR deleted. If it is puking with the EGR deleted it means one of 4 possibilities or a combination of the 4.
1. Blown head gaskets.
2. Cracked fuel rails/injector cups causing fuel to leak into the coolant and pushes out the degas bottle.
3. Coolant level is to high in the bottle.
4. The cap is bad and needs replaced.
Do you have a monitor in the truck? I am willing to bet you just cracked at least one of your heads if your letting the truck run up to hot on the idiot gauge on the dash. By the time that thing registers it is already to hot.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 9 Old 03-10-2013, 07:21 PM Thread Starter
No monitor just bought the truck about 2 weeks ago so buying an sct was going to happen in a few weeks but I guess I will be doing everything now!
Duf79 is offline
post #8 of 9 Old 03-10-2013, 07:24 PM Thread Starter
The temp gauge just went close to the H on the gauge once and then I parked the truck. I wasn't that far from the house when it happened.
Duf79 is offline
post #9 of 9 Old 03-10-2013, 07:42 PM
southend's Avatar
Re: White residue?
True, when it's running.
True.
True.
southend is offline
