Hard Start?? - Ford Powerstroke Diesel Forum
post #1 of 44 Old 03-07-2013, 03:11 PM Thread Starter
PyroTekRob's Avatar
Quoted: 332 Post(s)
Exclamation Hard Start??
I added this video to one of my other threads, but no one is responding. so maybe I can get some information here. (Click Image for Video)
Ever since I returned from my trip out to the desert my starts have taken longer an seem to be getting harder. Is this just striction or something else? How can I fix it?
Thanks
Rob
2006 F250 Amarillo 4x4 CCLB - 210,xxx
SCT Livewire TS - Tunes from Vivian (Eco, Tow, Tow w/ JB, Looney)
DrawTite Flip Over Goose
Leveling Kit - Wildpeak AT3Ws 325/75R18
Sinister Diesel Coolant Filter
Garrett Powermax Turbo
DC Power Engineering 185amp Alt.
BPD Heavy Air Oil Cooler
BPD EGR
LED bulb upgrades.
Curt Class V - Air Lift Load Level 5k Ult - Wireless Compr
PyroTekRob is offline
post #2 of 44 Old 03-08-2013, 09:48 AM
Mine is doing the exact same thing. Thought I had it fixed with new STC fitting and IPR valve, but doing the same thing again. Very frustrating. Does it always start even when it is hot?
thorx4md is offline
post #3 of 44 Old 03-08-2013, 09:54 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
I'm not a 6.0 guy but can't long start like that be the first sign of FICM taking a dump?
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #4 of 44 Old 03-08-2013, 09:57 AM
PowerStrokedRedneck's Avatar
Hard Start??
My Ex has a similar hard starting issue. Does yours only have the problem hot or cold?
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #5 of 44 Old 03-08-2013, 10:15 AM
Stumppy's Avatar
Whats your ficm voltage and battery voltage?
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
post #6 of 44 Old 03-08-2013, 12:14 PM Thread Starter
PyroTekRob's Avatar
Quoted: 332 Post(s)
Batt volt is just over 10.x
FICM running is 48v-49v ill check when i start next.
Usually when cold, havent had a chance to restart after hot, will check afyer work.
BPD EGR
LED bulb upgrades.
post #7 of 44 Old 03-08-2013, 12:20 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
sounds like your batteries aren't the best.. get them load tested at autozone or something! mine give me around 13V and what are the CCA on the batteries?
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #8 of 44 Old 03-08-2013, 12:44 PM Thread Starter
PyroTekRob's Avatar
Quoted: 332 Post(s)
Thats 10.x volt during crank
12.x power on, 13.x-14.x running
But ill get them checked.
BPD EGR
LED bulb upgrades.
post #9 of 44 Old 03-09-2013, 08:27 AM Thread Starter
PyroTekRob's Avatar
Quoted: 332 Post(s)
She starts hard, even while hot. Spent a hour on freeway, shut it down for about 10mins. An when i fired her back up, same thing.
BPD EGR
LED bulb upgrades.
post #10 of 44 Old 03-09-2013, 05:20 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Your batteries are good!
No one can help you with the limited info you provided.
Codes (hard/soft), IPR, ICP, and FICM for starters?
Any other info such as: smoke, smell, oil fill rate, fuel flow and pressure?
Almost all no starts are oil - high pressure, FICM, or fuel flow related. Most long cranks to start are glow-plug, fuel pressure, oil flow (wrong filter), low fuel pressure, FICM and slow to build HP oil.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
