Caster Adjustment? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-05-2013, 08:46 AM Thread Starter
06 Strokin's Avatar
Caster Adjustment?
So I installed a 2.5" leveling kit a few weeks ago and my caster isn't right. It wonders a little and is affected by bumpsteer at speed. Can the caster be adjusted to drie right again? I emailed 4 wheel parts down in Ft Worth about it and they said I would have to get the BD Caster adjusters. They said The adjusters and labor to put it on would be 650.00. Is this the only way to fix the caster problem? Thanks for the help in advance.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 5 Old 03-07-2013, 06:00 AM Thread Starter
06 Strokin's Avatar
Anyone know?
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #3 of 5 Old 03-07-2013, 06:17 AM
justinlogue5_0's Avatar
I am not sure about the 06 model, I would assume its the same as all superdutys but my local alignment shop said the adjusters are only about 35 to 50 bucks each and another 30 per side to install. I think it goes around the ball joint some how and is shaped like an oval. They turn it one way or the other to get the caster (lean) they nead. Not sure why a leveling kit would have messed with your caster though.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #4 of 5 Old 03-07-2013, 06:26 AM
wired1's Avatar
you need caster cams like this Icon Vehicle Dynamics 2005-2010 FSD Alignment Cam Kit - Front Suspension Alignment Cams
But most shops can get something like the icon ones depending on the amount of adjustment needed. I would go to an alignment shop that knows what there doing and you should be fine. should be around 150-200 all said and done with cams installed.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #5 of 5 Old 03-07-2013, 06:32 AM Thread Starter
06 Strokin's Avatar
Alrighty, well I'll do some calling around and see if someone can do it right around here. I knew there had to be another way. Thanks guys!
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
