Loss of Fuel Mileage - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-04-2013, 03:44 PM Thread Starter
Isotalo84's Avatar
Send a message via Skype™ to Isotalo84
So here is the problem I normally get around 14-16 mpg driving around town and some hwy. the last couple of times I had to fill up it averaged out to be about 11.2 mpg and 11.18 mpg. the only thing that has been done to the truck is a 4" turbo back no muffler, EGR delete, and SCT running the performance canned tune. I have not put in any gauges yet so I can not tell you what the EGTs are but the boost stays constant at about 8 pounds. It will max out at about 26-28 pounds. I am stumped at what the cause could be. that fuel came from the same place, the next tank will not just to see if its contaminated or not. Any help or thoughts would be most beneficial
Isotalo84 is offline
post #2 of 6 Old 03-04-2013, 05:12 PM
06Lariat_'s Avatar
That is what mine is lol idk what the issue is maybe ficm or inhectors
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #3 of 6 Old 03-04-2013, 07:43 PM
Fosterslaw77's Avatar
I had same problem boost at 8 lbs just driving. One day during oil change tire rotation found both front calipers locked up solid. After repair boost 2-3 lbs on same roads.
Fosterslaw77 is offline
post #4 of 6 Old 03-04-2013, 08:02 PM
Could be winter blend of diesel.
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #5 of 6 Old 03-05-2013, 06:20 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
winter blend would be small culprit.
tire pres
maf sensor
egr valve dirty
take off sct tune and tune trans only and see
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #6 of 6 Old 03-06-2013, 04:38 AM Thread Starter
Isotalo84's Avatar
I do not think that it is tire press since I check it on a weekly basis or the MAF sensor and I know it is not the EGR since I do not have one. I was thinking the same thing about the fuel though that is why the next tank will be from a different station. the reason that I do not think that it is the MAF sensor is because I am not receiving any codes. but thanks for all the info. I will keep you posted.
