Coolant puking after HG job - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-04-2013, 07:56 AM Thread Starter
Sno-Mow's Avatar
So I did a HG job and put in new (used) heads from a machine shop. Got 20 miles into it and I'm puking coolant out the degas and EGT climb rapidly to 1000*.
Never have had this issue before until now. I'm looking for possible solutions...
Thermostat done 10000 miles ago
20 miles on HG & heads
300 miles on rebuilt turbo
EGR cooler deleted 10000 miles ago
Oh, and I put a used radiator in when doing the HG job. Old one was leaking.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #2 of 9 Old 03-04-2013, 08:31 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Who's Headgaskets did you use?
OEM or Black Onyx?
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 9 Old 03-04-2013, 08:33 AM Thread Starter
Sno-Mow's Avatar
Oem studs torqued to 245
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #4 of 9 Old 03-05-2013, 06:34 AM
He asked what gaskets were used. The black onyx were found to have a high failure rate and are no longer recomended.
Were the heads checked for warpage and trueness?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 9 Old 03-05-2013, 08:07 AM Thread Starter
Sno-Mow's Avatar
Re: Coolant puking after HG job
The gaskets were ford. The heads were bought from a machine shop. According to them they were pressure checked and decked.
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #6 of 9 Old 03-05-2013, 08:08 AM Thread Starter
Sno-Mow's Avatar
Haha!! I have the A1 studs
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #7 of 9 Old 03-15-2013, 09:58 PM Thread Starter
Sno-Mow's Avatar
Figured it out...new thermostat and degas cap...FIXED!!
2003 F250 6.0l
Blizzard 8611PP
Sno-Mow is offline
post #8 of 9 Old 03-16-2013, 09:33 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
These caps fail all the time, any headgasket job gets a new degas bottle and cap just for piece of mind
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #9 of 9 Old 03-19-2013, 09:25 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Glad you found the problem! Good luck!!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
