Idler pulley question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-03-2013, 05:50 PM Thread Starter
06SuperDutyF250's Avatar
I have a squeaking idler pulley it seems....it seems to be wobbling a bit and all...is there any way to tighten it up possibly or just replaceable?
06SuperDutyF250 is offline
post #2 of 10 Old 03-04-2013, 01:57 AM
I have seldom found one that tightening helped, you useually have to replace.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 10 Old 03-04-2013, 12:57 PM
06Lariat_'s Avatar
You can try the soapy water on the belt to see if it stops. If it does that means the belt is bad.
06 Lariat SuperCab Long Bed
Leveling kit
Chrome bug deflector
Tri-Fold tonneau cover
4" MBRP turbo back straight pipe
Smoked cab lights
Blue spring upgrade
Riff raff boots
Edge insight cts overhead mount
06Lariat_ is offline
post #4 of 10 Old 03-04-2013, 03:01 PM Thread Starter
the actually pully wobbles abit tho, i dont think the belt is bad tho, it sqeaks only on cold startups, but the wobbling is there all the time
post #5 of 10 Old 03-04-2013, 03:21 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Squeaky cold till warm is pulley. Bearings finally heat up and are ok.
Just get a new one, they're cheap.
ALSO, soapy water means belt? No. Sure, you're putting water only on the belt. But think, if you make it wet, you lower the friction between the belt and pulley ever so slightly. So if your pulley is dragging because of bad bearings, you're actually letting the belt slip over the pulley allowing the pulley to spin slower and not squeak anymore
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 10 Old 03-05-2013, 07:33 AM
southend's Avatar
Re: Idler pulley question
Take it off, pop the bearing out, and replace the bearing. Don't bother buying the whole pulley.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #7 of 10 Old 03-05-2013, 07:36 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Mine does it too.
Where can you get the bearings?
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #8 of 10 Old 03-05-2013, 07:42 AM
southend's Avatar
Originally Posted by dfuzz78 View Post
Mine does it too.
Most of the time you can read a number on the bearing, I've gotten them from advanced, napa, and other independent auto parts houses. Probably no more than $5-8.
southend is offline
post #9 of 10 Old 03-05-2013, 07:57 AM
dfuzz78's Avatar
Ok, I'll look into it.
The squeak is driving me bonkers!
Denis "Lt. Sled"
dfuzz78 is offline
post #10 of 10 Old 03-05-2013, 03:06 PM Thread Starter
LOL ^ yea me too as well haha, ill have to get the bearing
