Broke radiator drain plug! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-03-2013, 01:04 PM Thread Starter
06 Strokin's Avatar
Question Broke radiator drain plug!
Well Im in the process of doing a coolant flush on my truck. I just drained all of the coolant out of the block and radiator. I was tightening the radiator drain plug back up and I overtightened it by accident and broke off the head of it!! Its not leaking so I can still drive it and drain the vc-9 and water out of the lower hose, but does anyone have an idea on how to get the broken plug out?
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
upgraded stc fitting
Cat ELC,
coolant filter
EGR delete
Reman tranny 126,xxx
06 Strokin is offline
post #2 of 11 Old 03-03-2013, 01:06 PM
ZMANN's Avatar
Quoted: 1782 Post(s)
easy out to a point
the snap the retention part off in the radiator ??
We Miss you Ronnie
ZMANN is offline
post #3 of 11 Old 03-03-2013, 01:10 PM
ZMANN's Avatar
if it has a retention ?
I can check I have one out LOL
it does have some means to hold it in hey the center is an allen head any of that left ??
We Miss you Ronnie
ZMANN is offline
post #4 of 11 Old 03-03-2013, 02:26 PM
The plug is trashed so why don't you just drill it out when you are read to drain? You could do that and crush the rest out, I imagine. Make sure you have your hands on the replacement before you do it.
Leopold is offline
post #5 of 11 Old 03-03-2013, 02:32 PM
powerstrokecrzy's Avatar
Quoted: 264 Post(s)
Re: Broke radiator drain plug!
Mine did the exact thing. Jammed a screw driver in there and got it to turn. Once out of the threads some pliers to squeeze the end together will get it out. pretty simple.
Sent from my DROID X2 using AutoGuide.Com Free App
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #6 of 11 Old 03-03-2013, 07:06 PM Thread Starter
06 Strokin's Avatar
I'll probably have to try the screwdriver trick and or drill it out. The hex head broke off so no allen head left on there unfortunately. And the ford house is closed today but I should be able to get one tomorrow! Thanks for the help guys!
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #7 of 11 Old 03-03-2013, 07:08 PM
sargar's Avatar
At least it isn't leaking....
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #8 of 11 Old 03-03-2013, 07:15 PM Thread Starter
06 Strokin's Avatar
Sargar thats what I said too. I'll mess with it this coming weekend while I change my oil cooler out.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
post #9 of 11 Old 03-03-2013, 07:45 PM
When my drain plug broke off, the inside of the stem still had a hex inside so I used an allen wrench. Are you sure there is no hex inside?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #10 of 11 Old 03-03-2013, 08:02 PM Thread Starter
06 Strokin's Avatar
Well Im not entirely sure now. I'll get a better look at it tomorrow after work.
06 F-250:
Custom tunes
5" exhaust
HD y-pipe
Banks elbow
AFE stage 2xp
zoodad mod
Harpoon mod
420s on 20x12
2.5" leveling kit
4" rear blocks
205/100cc
68mm KC Turbo
H-11's
OEM gaskets
RR
6.4 lift pump
Sump
Cat ELC,
coolant filter
EGR delete
