Running rough - now no start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-03-2013, 11:04 AM Thread Starter
Hey guys I need your help. I have a 2007 f-350 with 79,000 miles. Only mod is EGR delete. Truck has been experiencing long cranks and running rough so today I decided to change the oil and filters. I come out of the store and truck will not start. It crank and cranked forever. I let it sit for about 15 minutes and finally it stumbled and started. I drove it home, parked it in the garage and now it will not start. I removed the oil filter and canister fills with oil pretty quick when cranking. Pulled secondary fuel filter and cycled key and it filled quick as well. Also noticed that while cranking there is no oil pressure registering on the gauge in dash. Does this sound like a HPOP or snap-to connector? Any help will be appreciated.
thorx4md is offline
post #2 of 5 Old 03-03-2013, 11:18 AM
jesilvas's Avatar
Quoted: 3 Post(s)
What brand oil filter?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 5 Old 03-03-2013, 11:42 AM Thread Starter
All Motorcraft filters
thorx4md is offline
post #4 of 5 Old 03-03-2013, 11:45 AM Thread Starter
If it was a hpop or stc would it finally start like it did? I drove it probably 10 miles home. Now no start.
thorx4md is offline
post #5 of 5 Old 03-05-2013, 12:50 PM Thread Starter
Well, after reading a lot of the posts on here about no start conditions, I finally tore the truck apart. I replaced the STC fitting as well as the IPR valve. Not a bad job. Took me about 5 hours total. Put everything back together and crossed my fingers. After cranking for a little while the truck started and actually runs better than I can ever recall since I bought it used 2 years ago. I bought it used with 45,000 miles and it always had what felt like a little miss. Anyway, truck is running great. This information on this site is amazing. Thanks.
thorx4md is offline
