catalytic converter - Ford Powerstroke Diesel Forum
  #1
Old 03-01-2013, 07:09 PM
catalytic converter
Has anyone removed there cat converter from a 6.0 and passed emissions test in Arizona?
Jerry in gilbert
Reply With Quote Quick reply to this message
Old 03-12-2013, 06:57 PM
hey i am new here but to let you know i took my cat off and took a 1.5' long 1" wood drill bit and started drilling hole through the material on the inside. then once i had a bunch of holes i started chipping it all out, now my cat is just a big hollow cat, put it back on and passed the smog check in california because they just look under the truck and see it is there they cant tell the inside is hollow.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.1
